Ir para o conteúdo principal
Bugaboo Cameleon 1 and 3 Swivel Wheel Lock Replacement
O que você precisa
  1. Bugaboo Cameleon 1 and 3 Swivel Wheel Lock Replacement, Detach the seat from the frame: passo 1, imagem 1 %32
    • Push both the white square buttons under the seat at the same time, to remove the seat from the frame.
  2. Bugaboo Cameleon 1 and 3 Swivel Wheel Lock Replacement: passo 2, imagem 1 %32
    • Put the frame with the handle on the ground like shown in the picture, to have better access to the swivel wheels.
  3. Bugaboo Cameleon 1 and 3 Swivel Wheel Lock Replacement, Detach swivel wheel: passo 3, imagem 1 %32
    • Press the button above the swivel wheel, and pull out the swivel wheel
  4. Bugaboo Cameleon 1 and 3 Swivel Wheel Lock Replacement, Remove screws: passo 4, imagem 1 %32 Bugaboo Cameleon 1 and 3 Swivel Wheel Lock Replacement, Remove screws: passo 4, imagem 2 %32 Bugaboo Cameleon 1 and 3 Swivel Wheel Lock Replacement, Remove screws: passo 4, imagem 3 %32
    • Remove the two screws on the black cylinder on the bottom with the Torx screwdriver.
    • Make sure not to lose the screws, since you need them for the reassembly later.
  5. Bugaboo Cameleon 1 and 3 Swivel Wheel Lock Replacement: passo 5, imagem 1 %32
    • Remove the bottom part of the cylinder. You can use your screwdriver to pull it out.
  6. Bugaboo Cameleon 1 and 3 Swivel Wheel Lock Replacement, Remove old part: passo 6, imagem 1 %32 Bugaboo Cameleon 1 and 3 Swivel Wheel Lock Replacement, Remove old part: passo 6, imagem 2 %32 Bugaboo Cameleon 1 and 3 Swivel Wheel Lock Replacement, Remove old part: passo 6, imagem 3 %32
    • Push the old button, and place the flathead screwdriver behind the button
    • Push the button down and towards the opening of the cylinder.
    • Take out the wheel lock button and the spring, and make sure not to lose the spring.
  7. Bugaboo Cameleon 1 and 3 Swivel Wheel Lock Replacement, Attaching the new part: passo 7, imagem 1 %32 Bugaboo Cameleon 1 and 3 Swivel Wheel Lock Replacement, Attaching the new part: passo 7, imagem 2 %32
    • Pull the spring from the old part.
    • Attach it to pin on the new swivel wheel lock.
  8. Bugaboo Cameleon 1 and 3 Swivel Wheel Lock Replacement, Placing the new part in the stroller: passo 8, imagem 1 %32
    • Put the new part with the spring back inside the cylinder, in the orientation shown in the picture.
  9. Bugaboo Cameleon 1 and 3 Swivel Wheel Lock Replacement, Reassembling: passo 9, imagem 1 %32
    • Place the inner black cylinder back into the outer cylinder.
  10. Bugaboo Cameleon 1 and 3 Swivel Wheel Lock Replacement, Securing the part: passo 10, imagem 1 %32 Bugaboo Cameleon 1 and 3 Swivel Wheel Lock Replacement, Securing the part: passo 10, imagem 2 %32
    • Use the two screws and the Torx screwdriver to secure the parts.
  11. Bugaboo Cameleon 1 and 3 Swivel Wheel Lock Replacement, Attach the wheel: passo 11, imagem 1 %32
    • Click the wheel back onto the frame.
  12. Bugaboo Cameleon 1 and 3 Swivel Wheel Lock Replacement, Put the stroller the right side up.: passo 12, imagem 1 %32 Bugaboo Cameleon 1 and 3 Swivel Wheel Lock Replacement, Put the stroller the right side up.: passo 12, imagem 2 %32
    • The repair is now finished. Flip the frame back onto four wheels.
    • Place the seat back onto the frame.
Linha de Chegada
Uma outra pessoa concluiu este guia.
Documentos anexados
Rebecca Dowling
Membro desde: 04/24/18
647 Reputação
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 17
Duração total: 2,169
