Ir para o conteúdo principal
Bugaboo Cameleon 1 and 3 Handlebar Clip Replacement
O que você precisa
  1. Bugaboo Cameleon 1 and 3  Handlebar Clip Replacement, Remove old part: passo 1, imagem 1 %32 Bugaboo Cameleon 1 and 3  Handlebar Clip Replacement, Remove old part: passo 1, imagem 2 %32
    • Loosen the screw using the torx screwdriver.
    • Make sure to catch the nut that will fall out at the bottom, by holding the other hand underneath the clip.
    • Make sure not to lose the screw since you will need it later for the reassembly.
  2. Bugaboo Cameleon 1 and 3  Handlebar Clip Replacement, Remove screw: passo 2, imagem 1 %32
    • Use the screwdriver to push the screw up and out of the black part.
  3. Bugaboo Cameleon 1 and 3  Handlebar Clip Replacement: passo 3, imagem 1 %32
    • Remove the broken handlebar clip and the small part with the spring.
    • Make sure to keep the part with the spring, since that is not included if you use the 3D model used for this repair guide.
  4. Bugaboo Cameleon 1 and 3  Handlebar Clip Replacement: passo 4, imagem 1 %32 Bugaboo Cameleon 1 and 3  Handlebar Clip Replacement: passo 4, imagem 2 %32
    • Put the part with the spring back in.
    • Hold it in place while putting the new part back in place
  5. Bugaboo Cameleon 1 and 3  Handlebar Clip Replacement: passo 5, imagem 1 %32 Bugaboo Cameleon 1 and 3  Handlebar Clip Replacement: passo 5, imagem 2 %32
    • Place the torx screw back in place, and place the nut back onto the underside of the screw.
    • Hold it in place with one hand, while using the other hand to fasten the screw using the torx screwdriver.
  6. Bugaboo Cameleon 1 and 3  Handlebar Clip Replacement: passo 6, imagem 1 %32
    • Adjust the handlebar according to your needs.
    • Close the clip. All done!
Linha de Chegada
3 outras pessoas executaram este guia.
Documentos anexados
Rebecca Dowling
Membro desde: 04/24/18
692 Reputação
Autoria de 3 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 19
Ao todo: 2,174
