Introdução
Hard drive failed? Want to increase the storage capacity? This guide will help you open the Linkstation.
Notes:
1) I tried to replace the standard 500 GB hard drives with SSD items, it was not succcessful; the unit would not initialise.
You need to therefore buy the SSD version if you want the latest technology.
O que você precisa
Using a thin blade, gently prise the strip-sticker from the front of the unit.
There are two catches to release on the front face.
Using the iFixit opening tools, insert the first blade between the long opening and the first hole.
The second blade should be inserted between the third and fourth holes
Gently manipulate the tools to disengage the catches.
Open the case wider to be able to get the ifixit tools in the gap on the side of the unit - go to the next step.
The first catch is next to the rubber foot. Insert the tool under the lip and lift the side to disengage the catch
The second catch can be found at the beginning of the vents, use the same technique to open the catch
Repeat the steps on the opposite side and the lid will come off.
Pull the until out of the case, there are no catches, it is simply held in.
Place the unit on it's side and remove the metal plate that is clamped to the board.
Turn the unit over the remove the second plate.
The hard drives can now be removed.
The unit is now disassembled, assembly is simply done in the reverse order.
When reassembling the unit, pay attention to the orientation of the metal plates.
Uma outra pessoa concluiu este guia.
3 comentários
I have the 2x1TB version and DID manage to successfully replace HDD's with SSD's! I only had 500GB SSD's and don't recall having any problems (but it was years ago though). I do have a number of downloaded utilities, including TFTP Boot Recovery (presumably from Buffalo website) so it's possible I had to use this (too long ago to recall)!
I need the TFTP Boot Recovery files. Have you the files?
Thanks to all...I opened it without breaking anything thanks to you.
