Ir para o conteúdo principal
Brother PT-D200 Cutter Blade Replacement
  1. Brother PT-D200 Cutter Blade Replacement, Cutter Blade: passo 1, imagem 1 %32 Brother PT-D200 Cutter Blade Replacement, Cutter Blade: passo 1, imagem 2 %32
    • Open the back panel of the device by pressing down on and then pulling the indication arrows on the top center of the cover upward towards you.
  2. Brother PT-D200 Cutter Blade Replacement: passo 2, imagem 1 %32
    • Locate the cutter blade unit (mint green) as shown in the picture.
  3. Brother PT-D200 Cutter Blade Replacement: passo 3, imagem 1 %32 Brother PT-D200 Cutter Blade Replacement: passo 3, imagem 2 %32
    • Using the thumb and forefinger, pull up, applying a moderate amount of pressure until the cutter blade unit loosens and is removed.
    • The blade is sharp.
Conclusão
Blaire McCreary
Membro desde: 01/24/14
201 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 13-16, Regan Winter 2014 Membro de Cal Poly, Team 13-16, Regan Winter 2014
CPSU-REGAN-W14S13G16
Membros da 3
Autoria de 6 guias
Um comentário
Where can you order the replacement blade?
mistymeziere - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 36
Duração total: 3,051
