Ir para o conteúdo principal
Brother PT-90 Personal Labeler Disassembly
O que você precisa
  1. Brother PT-90 Personal Labeler Disassembly, Brother PT-90 Personal Labeler Disassembly: passo 1, imagem 1 %32 Brother PT-90 Personal Labeler Disassembly, Brother PT-90 Personal Labeler Disassembly: passo 1, imagem 2 %32
    • Start with your device off. The screen should be blank and not displaying anything.
    • Turn the device over so it's resting face down.
    • You should be able to see the model name of the label-maker, as well as a window in which you can view the label cartridge.
  2. Brother PT-90 Personal Labeler Disassembly: passo 2, imagem 1 %32 Brother PT-90 Personal Labeler Disassembly: passo 2, imagem 2 %32 Brother PT-90 Personal Labeler Disassembly: passo 2, imagem 3 %32
    • Using your thumb, press in and then upward on the fastener at the top of the device. The back of the device should come off easily.
    • Remove the 4 batteries located on the left side of the device.
  3. Brother PT-90 Personal Labeler Disassembly: passo 3, imagem 1 %32 Brother PT-90 Personal Labeler Disassembly: passo 3, imagem 2 %32 Brother PT-90 Personal Labeler Disassembly: passo 3, imagem 3 %32
    • To remove the label cartridge from the device, use a plastic opening tool from your iFixit tool kit.
  4. Brother PT-90 Personal Labeler Disassembly: passo 4, imagem 1 %32 Brother PT-90 Personal Labeler Disassembly: passo 4, imagem 2 %32 Brother PT-90 Personal Labeler Disassembly: passo 4, imagem 3 %32
    • Attach the J1 Screwdriver Bit to the extension tool from your tool kit.
    • Remove all of the screws from the back of the device.
  5. Brother PT-90 Personal Labeler Disassembly: passo 5, imagem 1 %32 Brother PT-90 Personal Labeler Disassembly: passo 5, imagem 2 %32
    • Once the screws have been removed, press as shown on the fastener.
    • Carefully open the device.
Linha de Chegada
Uma outra pessoa concluiu este guia.
Tessa Hathaway
Membro desde: 10/13/16
148 Reputação
Autoria de 1 guia
Equipe
University of Maine, Team 2-1, Diaz Fall 2016 Membro de University of Maine, Team 2-1, Diaz Fall 2016
UMAINE-DIAZ-F16S2G1
Membros da 3
Autoria de 2 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 12
Últimos 30 dias: 26
Duração total: 806
