Ir para o conteúdo principal
Brother PT-1290 LCD Screen Replacement
O que você precisa
  1. Brother PT-1290 LCD Screen Replacement, Removing the back piece of the label maker.: passo 1, imagem 1 %32 Brother PT-1290 LCD Screen Replacement, Removing the back piece of the label maker.: passo 1, imagem 2 %32
    • There is a plastic tab located on the back of the label maker near the top. The tab has ridges on it to help you identify where to press. Push on this tab to release the back of the label maker.
    • Gently pull the label maker apart - it will split in half.
    • Be careful! The electronics inside are very sensitive and easily damaged.
  2. Brother PT-1290 LCD Screen Replacement, Removing batteries or AC adapter.: passo 2, imagem 1 %32 Brother PT-1290 LCD Screen Replacement, Removing batteries or AC adapter.: passo 2, imagem 2 %32
    • Remove the AAA batteries before you proceed on to replacing the tape cassette.
  3. Brother PT-1290 LCD Screen Replacement, Replacing tape cassette.: passo 3, imagem 1 %32 Brother PT-1290 LCD Screen Replacement, Replacing tape cassette.: passo 3, imagem 2 %32
    • Align and insert a new tape cassette. Make sure the center of the cassette snaps into place. The tape must feed between the tape guides.
    • If the ribbon has become too loose, use your finger to turn the white wheel in the direction of the arrow on the tape cassette. This will wind up any excess tape.
    • Only use Brother TZ tapes with this machine.
  4. Brother PT-1290 LCD Screen Replacement, Evaluating: passo 4, imagem 1 %32
    • Place the batteries back inside, then close the cover.
    • Check that all six batteries are inserted correctly.
  5. Brother PT-1290 LCD Screen Replacement, Feeding Tape.: passo 5, imagem 1 %32
    • To test the new cassette, make a new label. Press "Shift" and "Print" to feed the tape, then use the cutting lever on the upper-right corner of the machine.
  6. Brother PT-1290 LCD Screen Replacement, Turn over device to remove batteries.: passo 6, imagem 1 %32 Brother PT-1290 LCD Screen Replacement, Turn over device to remove batteries.: passo 6, imagem 2 %32 Brother PT-1290 LCD Screen Replacement, Turn over device to remove batteries.: passo 6, imagem 3 %32
    • Turn the device to it's side toward the bottom of the keyboard. Then pop open the case and remove the batteries.
  7. Brother PT-1290 LCD Screen Replacement, Back of device: passo 7, imagem 1 %32 Brother PT-1290 LCD Screen Replacement, Back of device: passo 7, imagem 2 %32 Brother PT-1290 LCD Screen Replacement, Back of device: passo 7, imagem 3 %32
    • Remove back of device and set aside.
  8. Brother PT-1290 LCD Screen Replacement, Remove screws: passo 8, imagem 1 %32 Brother PT-1290 LCD Screen Replacement, Remove screws: passo 8, imagem 2 %32 Brother PT-1290 LCD Screen Replacement, Remove screws: passo 8, imagem 3 %32
    • Remove all 1/4 inch screws(6 total) with a (+PH00) screwdriver. Open slowly not to damage the display data cable.
  9. Brother PT-1290 LCD Screen Replacement, Remove flat panel: passo 9, imagem 1 %32 Brother PT-1290 LCD Screen Replacement, Remove flat panel: passo 9, imagem 2 %32 Brother PT-1290 LCD Screen Replacement, Remove flat panel: passo 9, imagem 3 %32
    • Use a plastic opening tool to remove the flat-panel membrane keyboard. Lift up and set aside.
  10. Brother PT-1290 LCD Screen Replacement, Remove: passo 10, imagem 1 %32 Brother PT-1290 LCD Screen Replacement, Remove: passo 10, imagem 2 %32 Brother PT-1290 LCD Screen Replacement, Remove: passo 10, imagem 3 %32
    • Use a spudger to aid in removing the keyboard.
    • Gently lift out while removing the LCD screen that is connected to the data cable and finishing removing.
  11. Brother PT-1290 LCD Screen Replacement, Opening Device: passo 11, imagem 1 %32 Brother PT-1290 LCD Screen Replacement, Opening Device: passo 11, imagem 2 %32 Brother PT-1290 LCD Screen Replacement, Opening Device: passo 11, imagem 3 %32
    • In order to start the process of replacing the LCD you would have to go trough the steps as if replacing the cartridge or batteries we show you in this guide to open the device.
    • Once you get to that part, then is time to utilize some "tools." A couple of Phillips screwdrivers will be needed to remove the 5 screws that secure the plate and gain access to the LCD screen.
  12. Brother PT-1290 LCD Screen Replacement, Removing screws from  plate: passo 12, imagem 1 %32 Brother PT-1290 LCD Screen Replacement, Removing screws from  plate: passo 12, imagem 2 %32 Brother PT-1290 LCD Screen Replacement, Removing screws from  plate: passo 12, imagem 3 %32
    • Once you start working to remove the screws, you'll find one that has a very narrow access, which is where you will need a thinner screwdriver (PH00).
  13. Brother PT-1290 LCD Screen Replacement, Remove screws holding keyboard: passo 13, imagem 1 %32 Brother PT-1290 LCD Screen Replacement, Remove screws holding keyboard: passo 13, imagem 2 %32 Brother PT-1290 LCD Screen Replacement, Remove screws holding keyboard: passo 13, imagem 3 %32
    • Once you remove the back plate, you will have access to the area where the keyboard is located, so you could use the guide "How to replace the Keyboard" to remove it.
    • Three more screws need to be removed to be able to lift the keyboard.
    • Also, you will have to remove the small metal plate on top of the black connector with the red and black cables.
  14. Brother PT-1290 LCD Screen Replacement, Removing the wiring: passo 14, imagem 1 %32 Brother PT-1290 LCD Screen Replacement, Removing the wiring: passo 14, imagem 2 %32 Brother PT-1290 LCD Screen Replacement, Removing the wiring: passo 14, imagem 3 %32
    • At this point, you have removed the screws. Carefully follow these steps:
    • Unhook the connector with the orange and blue wire
    • There is also a hook that holds the yellow, red, orange and green cables, the spudger will be all you need to slide them out to unhook them.
    • The black connector with the red and black cables, has to be removed as well. Step 3 was to remove he screw that holds the metal plate that holds it in place, so at this point, just slide upwards.
  15. Brother PT-1290 LCD Screen Replacement, Removing the Keyboard to access the LCD: passo 15, imagem 1 %32 Brother PT-1290 LCD Screen Replacement, Removing the Keyboard to access the LCD: passo 15, imagem 2 %32 Brother PT-1290 LCD Screen Replacement, Removing the Keyboard to access the LCD: passo 15, imagem 3 %32
    • After removing the last three Philips screws, the keyboard has to be removed. To do so, you'll have to hold it making sure the four hooks with red circles are properly loose to avoid breaking them.
    • Pull it out, gently bur firmly
    • Make sure once it becomes loose, you can proceed to remove the LCD which is being held by two more hooks marked with orange circles. You will need the Spudger to hold them back while pulling the screen with your other hand.
  16. Brother PT-1290 LCD Screen Replacement, Replacing the LCD: passo 16, imagem 1 %32 Brother PT-1290 LCD Screen Replacement, Replacing the LCD: passo 16, imagem 2 %32 Brother PT-1290 LCD Screen Replacement, Replacing the LCD: passo 16, imagem 3 %32
    • Keyboard was successfully removed, now, holding the front (keyboard)plate, you'll be removing the face plate.
    • If the face plate doesn't get removed, it will be close to impossible to remove the LCD or you'll find yourself breaking some of the hooks that are holding it on place.
    • Remove and replace the LCD screen making sure the display data cable doesn't get damaged in the process.
    • Follow the steps backwards in the order they were removed, to be able to put the parts together and remain your printing job.
Conclusão
Uma outra pessoa concluiu este guia.
Yadira Jones
Membro desde: 10/25/14
273 Reputação
Autoria de 2 guias
Equipe
Gateway, Team 1-4, Johnson Fall 2014 Membro de Gateway, Team 1-4, Johnson Fall 2014
GCC-JOHNSON-F14S1G4
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 33
Duração total: 1,880
