Ir para o conteúdo principal
Brother PT-1290 Face Plate Replacement
O que você precisa
  1. Brother PT-1290  Face Plate Replacement, Turn over device to remove batteries.: passo 1, imagem 1 %32 Brother PT-1290  Face Plate Replacement, Turn over device to remove batteries.: passo 1, imagem 2 %32 Brother PT-1290  Face Plate Replacement, Turn over device to remove batteries.: passo 1, imagem 3 %32
    • Turn the device to it's side toward the bottom of the keyboard. Then pop open the case and remove the batteries.
  2. Brother PT-1290  Face Plate Replacement, Back of device: passo 2, imagem 1 %32 Brother PT-1290  Face Plate Replacement, Back of device: passo 2, imagem 2 %32 Brother PT-1290  Face Plate Replacement, Back of device: passo 2, imagem 3 %32
    • Remove back of device and set aside.
  3. Brother PT-1290  Face Plate Replacement, Remove screws: passo 3, imagem 1 %32 Brother PT-1290  Face Plate Replacement, Remove screws: passo 3, imagem 2 %32 Brother PT-1290  Face Plate Replacement, Remove screws: passo 3, imagem 3 %32
    • Remove all 1/4 inch screws(6 total) with a (+PH00) screwdriver. Open slowly not to damage the display data cable.
  4. Brother PT-1290  Face Plate Replacement, Remove flat panel: passo 4, imagem 1 %32 Brother PT-1290  Face Plate Replacement, Remove flat panel: passo 4, imagem 2 %32 Brother PT-1290  Face Plate Replacement, Remove flat panel: passo 4, imagem 3 %32
    • Use a plastic opening tool to remove the flat-panel membrane keyboard. Lift up and set aside.
  5. Brother PT-1290  Face Plate Replacement, Remove: passo 5, imagem 1 %32 Brother PT-1290  Face Plate Replacement, Remove: passo 5, imagem 2 %32 Brother PT-1290  Face Plate Replacement, Remove: passo 5, imagem 3 %32
    • Use a spudger to aid in removing the keyboard.
    • Gently lift out while removing the LCD screen that is connected to the data cable and finishing removing.
  6. Brother PT-1290  Face Plate Replacement, Removing the LCD screen.: passo 6, imagem 1 %32 Brother PT-1290  Face Plate Replacement, Removing the LCD screen.: passo 6, imagem 2 %32 Brother PT-1290  Face Plate Replacement, Removing the LCD screen.: passo 6, imagem 3 %32
    • Now that you have removed your keyboard. Turn the device over carefully.
    • Pop of LCD black cover.
    • Use the spudger to gently press out the LCD screen.
  7. Brother PT-1290  Face Plate Replacement, Switching out faceplate.: passo 7, imagem 1 %32
    • Change out old damaged face plate with your new face plate.
Conclusão
Lorraine Canez
Membro desde: 10/25/14
318 Reputação
Autoria de 3 guias
Equipe
Gateway, Team 1-4, Johnson Fall 2014 Membro de Gateway, Team 1-4, Johnson Fall 2014
GCC-JOHNSON-F14S1G4
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 12
Duração total: 163
