Introdução
The entire motor/gear assembly housing should be removed before starting.
O que você precisa
Using the metal spudger, swivel the pin so that the print roller lever loosens.
5 comentários
Hi everybody ,does anyone knows were I can by such a lever ?
TBH
Did anyone find a source for this part?
Unfortunately very discontinued. Until someone adds it to thingverse there's not much that can be done.
UN8026001 ROLLER HOLDER ASSY PT100/110
UN8031001 ROLLER HOLDER SPRING PT100
UN8032000 ROLLER RELEASE LEVER PT100/110
I can fix these by using plastic weld to rebuild the edging. I was totally successful.
