Ir para o conteúdo principal
Brother PT-1010 Keyboard Replacement
O que você precisa
  1. Brother PT-1010 Keyboard Replacement, Remove Back Cover: passo 1, imagem 1 %32
    • Flip the device over and press down on the indication arrows located at the top center of the back cover and pull it open.
  2. Brother PT-1010 Keyboard Replacement: passo 2, imagem 1 %32
    • Remove batteries, cassette tape, and cutter blade.
  3. Brother PT-1010 Keyboard Replacement, Remove Screws: passo 3, imagem 1 %32
    • Use a phillips size #00 screwdriver to unscrew the 5 corner screws circled in the picture.
  4. Brother PT-1010 Keyboard Replacement, Separate Device: passo 4, imagem 1 %32
    • Separate the top of the device from the bottom. Be very cautious when you separate the device, there is a ribbon attaching the top to the bottom.
  5. Brother PT-1010 Keyboard Replacement, Remove side panels: passo 5, imagem 1 %32
    • Remove the two black side panels. They will easily fall out so just move them to the side until you are putting your device back together.
  6. Brother PT-1010 Keyboard Replacement, Pull Ribbon Out: passo 6, imagem 1 %32 Brother PT-1010 Keyboard Replacement, Pull Ribbon Out: passo 6, imagem 2 %32 Brother PT-1010 Keyboard Replacement, Pull Ribbon Out: passo 6, imagem 3 %32
    • Using your index finger and thumb, pull out the golden ribbon from the green circuit board.
  7. Brother PT-1010 Keyboard Replacement, Remove Screws from Circuit Board: passo 7, imagem 1 %32
    • Use a phillips size #00 screwdriver to remove the two screws, circled in red, from the green circuit board.
  8. Brother PT-1010 Keyboard Replacement, Remove Circuit Board: passo 8, imagem 1 %32
    • Carefully remove the green circuit board by pulling it straight up. Be careful not to break the LCD cable ribbon that connects the circuit board to the device.
    • The ribbon is very fragile so be careful to break it when pulling up on the circuit board.
  9. Brother PT-1010 Keyboard Replacement, Peel Off Rubber Keyboard: passo 9, imagem 1 %32 Brother PT-1010 Keyboard Replacement, Peel Off Rubber Keyboard: passo 9, imagem 2 %32 Brother PT-1010 Keyboard Replacement, Peel Off Rubber Keyboard: passo 9, imagem 3 %32
    • Underneath the circuit board you will find the rubber keyboard. Peel this off and remove it from the device.
Conclusão
Haley Sweet
Membro desde: 10/30/14
460 Reputação
Autoria de 4 guias
Equipe
Baylor, Team 4-4, Williams Fall 2014 Membro de Baylor, Team 4-4, Williams Fall 2014
BU-WILLIAMS-F14S4G4
Membros da 4
Autoria de 4 guias
3 comentários
Hi!
Thanks for this very helpful and detailed set of instructions. One small suggestion - assuming that replacing the keyboard means you need a working one to replace the old one with, you might want to consider adding “Parts: replacement keyboard” instead of “No parts required.”
Cheers,
Maria B
Maria Bitterli - Responder
Please specify what is being replaced. Is the rubber keyboard the part that needs to be replaced?
Sincere Cavalier - Responder
Screen is dull, what to do
Judy Baranczyk - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 11
Últimos 30 dias: 32
Duração total: 3,027
