Ir para o conteúdo principal
Brother PT-1010 Battery Replacement
  1. Brother PT-1010 Battery Replacement, Removing Back Panel: passo 1, imagem 1 %32
    • Turn device so you are looking down at the top
  2. Brother PT-1010 Battery Replacement: passo 2, imagem 1 %32 Brother PT-1010 Battery Replacement: passo 2, imagem 2 %32
    • Press firmly on arrow indicator and pull panel toward you.
  3. Brother PT-1010 Battery Replacement, Remove Dead Batteries: passo 3, imagem 1 %32
    • Remove dead batteries one at a time by pulling up on the side indicated with a + symbol.
    • Make sure the battery compartment is empty and clear of debris.
  4. Brother PT-1010 Battery Replacement: passo 4, imagem 1 %32 Brother PT-1010 Battery Replacement: passo 4, imagem 2 %32
    • Insert the first battery with the flat side (indicated by a - symbol on the battery) facing to the left of the battery compartment.
    • Do the same thing to insert the next 2 batteries.
  5. Brother PT-1010 Battery Replacement: passo 5, imagem 1 %32
    • The next 3 batteries will be inserted on top of the others.
    • Insert the 4th battery with the flat side (indicated by the - symbol on the battery) facing to the right of the battery compartment.
  6. Brother PT-1010 Battery Replacement: passo 6, imagem 1 %32
    • Repeat step 5 to insert the last 2 batteries.
  7. Brother PT-1010 Battery Replacement, Replace Back Panel: passo 7, imagem 1 %32
    • Reinsert back panel.
Conclusão
Uma outra pessoa concluiu este guia.
Haley Sweet
Membro desde: 10/30/14
460 Reputação
Autoria de 4 guias
Equipe
Baylor, Team 4-4, Williams Fall 2014 Membro de Baylor, Team 4-4, Williams Fall 2014
BU-WILLIAMS-F14S4G4
Membros da 4
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 16
Duração total: 4,813
