Ir para o conteúdo principal
Brother MFC-490CW Wireless module Replacement
O que você precisa
  1. Brother MFC-490CW Wireless module Replacement, Remove screws holding the front panel: passo 1, imagem 1 %32
    • Use a Phillips #2 screwdriver to remove the three 12.1 mm screws holding the control panel in place.
  2. Brother MFC-490CW Wireless module Replacement, Unplug the panel from the rest of the printer: passo 2, imagem 1 %32 Brother MFC-490CW Wireless module Replacement, Unplug the panel from the rest of the printer: passo 2, imagem 2 %32 Brother MFC-490CW Wireless module Replacement, Unplug the panel from the rest of the printer: passo 2, imagem 3 %32
    • Lift up the front panel from the device.
    • Gently lift up and disconnect the data cables that attach the panel to the printer.
  3. Brother MFC-490CW Wireless module Replacement, Remove the screw: passo 3, imagem 1 %32
    • Unscrew the 14.1mm screw located at the left side of the device.
    • Unscrew the 12.1mm screw to the right of the 14.1mm screw.
  4. Brother MFC-490CW Wireless module Replacement: passo 4, imagem 1 %32 Brother MFC-490CW Wireless module Replacement: passo 4, imagem 2 %32 Brother MFC-490CW Wireless module Replacement: passo 4, imagem 3 %32
    • Pry open the left front panel away from the printer
    • Be careful. The panel is attached with a data cable.
  5. Brother MFC-490CW Wireless module Replacement: passo 5, imagem 1 %32 Brother MFC-490CW Wireless module Replacement: passo 5, imagem 2 %32
    • Carefully unplug the connector attached to the device.
  6. Brother MFC-490CW Wireless module Replacement, Remove the module from the panel: passo 6, imagem 1 %32 Brother MFC-490CW Wireless module Replacement, Remove the module from the panel: passo 6, imagem 2 %32 Brother MFC-490CW Wireless module Replacement, Remove the module from the panel: passo 6, imagem 3 %32
    • Separate the two clips that hold the module in place.
    • Lift up the module.
Conclusão
To reassemble your wireless module, follow these instructions in reverse order.
Matt
Membro desde: 10/30/14
64 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team 4-4, Miles Fall 2014 Membro de UMass Dartmouth, Team 4-4, Miles Fall 2014
UMASSD-MILES-F14S4G4
3 Membros
Autoria de 11 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 21
Ao todo: 2,187
