Ir para o conteúdo principal
Brother MFC-490CW Scanning Glass Replacement
O que você precisa
  1. Brother MFC-490CW Scanning Glass Replacement, Removing Scanner Header: passo 1, imagem 1 %32 Brother MFC-490CW Scanning Glass Replacement, Removing Scanner Header: passo 1, imagem 2 %32 Brother MFC-490CW Scanning Glass Replacement, Removing Scanner Header: passo 1, imagem 3 %32
    • Twist green section to allow the scanner head to have a full range of motion.
  2. Brother MFC-490CW Scanning Glass Replacement, Removing Scan Header: passo 2, imagem 1 %32 Brother MFC-490CW Scanning Glass Replacement, Removing Scan Header: passo 2, imagem 2 %32 Brother MFC-490CW Scanning Glass Replacement, Removing Scan Header: passo 2, imagem 3 %32
    • To remove scanner head, open it halfway as possible and slide the hinges out of place and the head will be removed.
  3. Brother MFC-490CW Scanning Glass Replacement, Remove scanner head connection to printer: passo 3, imagem 1 %32 Brother MFC-490CW Scanning Glass Replacement, Remove scanner head connection to printer: passo 3, imagem 2 %32 Brother MFC-490CW Scanning Glass Replacement, Remove scanner head connection to printer: passo 3, imagem 3 %32
    • The panels to expose the cords will become exposed when the head is removed.
    • Pull all colored cords from the printer and unscrew the other wire to be fully removed.
    • Pull the black tab from the printer to remove.
  4. Brother MFC-490CW Scanning Glass Replacement, Removing the bottom screws: passo 4, imagem 1 %32 Brother MFC-490CW Scanning Glass Replacement, Removing the bottom screws: passo 4, imagem 2 %32
    • Once scanner is free from the printer remove all the screws on the bottom base
    • Use a #2 Philips head screw driver to remove the two 12.1mm screws.
  5. Brother MFC-490CW Scanning Glass Replacement, Exposing scanner glass: passo 5, imagem 1 %32 Brother MFC-490CW Scanning Glass Replacement, Exposing scanner glass: passo 5, imagem 2 %32 Brother MFC-490CW Scanning Glass Replacement, Exposing scanner glass: passo 5, imagem 3 %32
    • To separate the base from the glass hold upright and separate along the edge where you removed the screws.
    • Use hands to expose the glass.
    • Keep track flat once glass is removed as to not lose little parts.
  6. Brother MFC-490CW Scanning Glass Replacement, Replacing scanner glass: passo 6, imagem 1 %32 Brother MFC-490CW Scanning Glass Replacement, Replacing scanner glass: passo 6, imagem 2 %32 Brother MFC-490CW Scanning Glass Replacement, Replacing scanner glass: passo 6, imagem 3 %32
    • Disconnect the glass from the tracks.
    • Remove old or broken glass.
    • Replace with adhesive tape along the bottom of the header and reassemble.
Conclusão
Equipe
UMass Dartmouth, Team 4-4, Miles Fall 2014 Membro de UMass Dartmouth, Team 4-4, Miles Fall 2014
UMASSD-MILES-F14S4G4
Membros da 3
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 75
Duração total: 3,764
