Ir para o conteúdo principal
Brother MFC-490CW Front Panel Replacement
O que você precisa
  1. Brother MFC-490CW Front Panel Replacement, Remove screws holding the front panel: passo 1, imagem 1 %32
    • Use a Phillips #2 screwdriver to remove the three 12.1 mm screws holding the control panel in place.
  2. Brother MFC-490CW Front Panel Replacement, Unplug the panel from the rest of the printer: passo 2, imagem 1 %32 Brother MFC-490CW Front Panel Replacement, Unplug the panel from the rest of the printer: passo 2, imagem 2 %32 Brother MFC-490CW Front Panel Replacement, Unplug the panel from the rest of the printer: passo 2, imagem 3 %32
    • Lift up the front panel from the device.
    • Gently lift up and disconnect the data cables that attach the panel to the printer.
Conclusão
To reassemble the front panel, follow these instructions in reverse order.
Matt
Membro desde: 10/30/14
64 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team 4-4, Miles Fall 2014 Membro de UMass Dartmouth, Team 4-4, Miles Fall 2014
UMASSD-MILES-F14S4G4
Membros da 3
Autoria de 8 guias
Um comentário
Be sure the three plastic tabs on the bottom of the black front cover are inserted fully when you snap the cover back into place or else you will get a message saying the ink door is not closed.
Raymond Rinaldi - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 9
Duração total: 1,690
