Introdução
This guide tells you how to remove the drum & toner unit from the printer before you perform any maintenance.
  1. Press the front cover release button.
    • Press the front cover release button.
    • Keep the button pressed and pull the cover toward yourself.
  2. With the front cover in the downward position, the drum & toner unit will be visible.
    • With the front cover in the downward position, the drum & toner unit will be visible.
    • Grab the black-and-yellow handle on the unit. Lift unit up and pull it out of the printer.
Conclusão
3 outras pessoas concluíram este guia.
Guy Patterson
90 reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 4-14, Forte Winter 2010 Membro de Cal Poly, Team 4-14, Forte Winter 2010
CPSU-FORTE-W10S4G14
5 Membros
5 Guides authored
Visualizar Estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 14
Todo: 7,885
