Ir para o conteúdo principal
Brother DCP-L2550DW Toner Cartridge Replacement
O que você precisa
  1. Brother DCP-L2550DW Toner Cartridge Replacement, Toner Cartridge: passo 1, imagem 1 %32 Brother DCP-L2550DW Toner Cartridge Replacement, Toner Cartridge: passo 1, imagem 2 %32
    • Unplug your printer from the outlet. Identify your printer and the toner cartridge required.
    • The printer recommends only two cartridges, TN-730 and TN-760.
  2. Brother DCP-L2550DW Toner Cartridge Replacement: passo 2, imagem 1 %32 Brother DCP-L2550DW Toner Cartridge Replacement: passo 2, imagem 2 %32 Brother DCP-L2550DW Toner Cartridge Replacement: passo 2, imagem 3 %32
    • Pull on the tab to open the front plate of your printer.
  3. Brother DCP-L2550DW Toner Cartridge Replacement: passo 3, imagem 1 %32 Brother DCP-L2550DW Toner Cartridge Replacement: passo 3, imagem 2 %32 Brother DCP-L2550DW Toner Cartridge Replacement: passo 3, imagem 3 %32
    • Pull on the green handle to remove the drum unit of your printer.
  4. Brother DCP-L2550DW Toner Cartridge Replacement: passo 4, imagem 1 %32 Brother DCP-L2550DW Toner Cartridge Replacement: passo 4, imagem 2 %32 Brother DCP-L2550DW Toner Cartridge Replacement: passo 4, imagem 3 %32
    • Place the drum unit on a clean flat surface.
    • Press down on the green button at the bottom left corner of the drum unit to unlock the toner cartridge.
    • Remove the toner cartridge from the drum unit.
  5. Brother DCP-L2550DW Toner Cartridge Replacement: passo 5, imagem 1 %32 Brother DCP-L2550DW Toner Cartridge Replacement: passo 5, imagem 2 %32 Brother DCP-L2550DW Toner Cartridge Replacement: passo 5, imagem 3 %32
    • Insert the new toner cartridge into the drum unit by placing it on top of the drum unit and pressing it down, ensuring it is in the locked position.
    • Do not touch the ink roll of the cartridge. It can compromise the quality of the ink.
  6. Brother DCP-L2550DW Toner Cartridge Replacement: passo 6, imagem 1 %32 Brother DCP-L2550DW Toner Cartridge Replacement: passo 6, imagem 2 %32 Brother DCP-L2550DW Toner Cartridge Replacement: passo 6, imagem 3 %32
    • Insert the drum unit back into the printer by placing it at the edge of the opening and sliding it inside until it locks in place.
  7. Brother DCP-L2550DW Toner Cartridge Replacement: passo 7, imagem 1 %32 Brother DCP-L2550DW Toner Cartridge Replacement: passo 7, imagem 2 %32 Brother DCP-L2550DW Toner Cartridge Replacement: passo 7, imagem 3 %32
    • Close the front plate and ensure it is in the locked position.
  8. Brother DCP-L2550DW Toner Cartridge Replacement: passo 8, imagem 1 %32
    • Replacement completed. Plug the printer back in the outlet and test it out. You can now use your printer.
Conclusão
Uma outra pessoa concluiu este guia.
Syed Momin Raza
Membro desde: 01/09/24
157 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 24
Duração total: 78
