Ir para o conteúdo principal
Brother CS6000i LCD Screen Replacement
O que você precisa
  1. Brother CS6000i LCD Screen Replacement, Body: passo 1, imagem 1 %32 Brother CS6000i LCD Screen Replacement, Body: passo 1, imagem 2 %32
    • Remove the five 20 mm Phillips #2 screws on the back of the device.
    • Remove the single 28 mm Phillips #2 screw on the back of the device.
    • Remove the single 23 mm Phillips #2 screw on the back of the device.
  2. Brother CS6000i LCD Screen Replacement: passo 2, imagem 1 %32 Brother CS6000i LCD Screen Replacement: passo 2, imagem 2 %32
    • Pull the white cover off.
  3. Brother CS6000i LCD Screen Replacement: passo 3, imagem 1 %32 Brother CS6000i LCD Screen Replacement: passo 3, imagem 2 %32
    • Remove the final screw, a 11 mm Phillips #2.
    • After removing all eight screws, you will have five 2 mm screws, one 28 mm screw, one 23 mm screw, and one 11 mm screw, all of which are Phillips #2.
  4. Brother CS6000i LCD Screen Replacement: passo 4, imagem 1 %32 Brother CS6000i LCD Screen Replacement: passo 4, imagem 2 %32 Brother CS6000i LCD Screen Replacement: passo 4, imagem 3 %32
    • Slightly pull apart the two halves of the machine, taking care not to strain the attached cables.
    • Unhook the white wires that are connected to the motherboard.
    • Fully separate the two halves.
  5. Brother CS6000i LCD Screen Replacement, LCD Screen: passo 5, imagem 1 %32
    • Remove the two 10 mm Philips #2 screws that secure the screen.
    • Unplug the ribbon cable located at the top of the circuit board, then gently remove the LCD screen.
Conclusão
Uma outra pessoa concluiu este guia.
Wasim Benbrahim
Membro desde: 11/04/24
152 Reputação
Autoria de 1 guia
Equipe
Cuesta, Team 20-1, Krynen Fall 2024 Membro de Cuesta, Team 20-1, Krynen Fall 2024
CUESTA-KRYNEN-F24S20G1
5 Membros
Autoria de 8 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 20
Ao todo: 228
