Ir para o conteúdo principal
Broan-Nutone NU230BL Filter and Light Replacement
O que você precisa
  1. Broan-Nutone NU230BL Filter and Light Replacement, Filter and Light: passo 1, imagem 1 %32
    • Make sure the fan switch is centered, and the light switch is set to "off" to avoid any injuries.
  2. Broan-Nutone NU230BL Filter and Light Replacement: passo 2, imagem 1 %32
    • Squeeze both ends of the bulb cover to pop it out of the slots.
  3. Broan-Nutone NU230BL Filter and Light Replacement: passo 3, imagem 1 %32 Broan-Nutone NU230BL Filter and Light Replacement: passo 3, imagem 2 %32
    • Make sure the lightbulb is cool before handling to avoid burns.
    • Unscrew and remove the lightbulb by turning it counterclockwise.
  4. Broan-Nutone NU230BL Filter and Light Replacement: passo 4, imagem 1 %32 Broan-Nutone NU230BL Filter and Light Replacement: passo 4, imagem 2 %32 Broan-Nutone NU230BL Filter and Light Replacement: passo 4, imagem 3 %32
    • Twist the latch above the filter clockwise.
    • Slide the filter out by gently pulling it.
  5. Broan-Nutone NU230BL Filter and Light Replacement: passo 5, imagem 1 %32 Broan-Nutone NU230BL Filter and Light Replacement: passo 5, imagem 2 %32 Broan-Nutone NU230BL Filter and Light Replacement: passo 5, imagem 3 %32
    • Insert the new filter.
    • Rotate the retaining latch counterclockwise to secure the filter.
  6. Broan-Nutone NU230BL Filter and Light Replacement: passo 6, imagem 1 %32 Broan-Nutone NU230BL Filter and Light Replacement: passo 6, imagem 2 %32
    • Install the new lightbulb and turn it clockwise.
  7. Broan-Nutone NU230BL Filter and Light Replacement: passo 7, imagem 1 %32 Broan-Nutone NU230BL Filter and Light Replacement: passo 7, imagem 2 %32
    • Reinsert the lightbulb cover by pressing both sides and fitting the cover's tabs into the slots.
Conclusão
Your range hood is good-to-go!
Uma outra pessoa concluiu este guia.
Mahdi M
Membro desde: 01/17/22
169 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 33
Duração total: 737
