Pular para o conteúdo principal
Introdução
This guide will take you through the process of properly removing the motherboard of the device. Removal of the motherboard is necessary to access additional components that may need fixing.
Peças
Nenhum componente especificado.
  1. Remove three 8mm screws from the left side of the device. Remove four 8mm screws from the right side of the device. Remove four 8mm screws from the right side of the device.
    • Remove three 8mm screws from the left side of the device.
    • Remove four 8mm screws from the right side of the device.
  2. Apply pressure on the SD card to pop it out of the port. Remove the card by pulling it out. Remove the card by pulling it out.
    • Apply pressure on the SD card to pop it out of the port.
    • Remove the card by pulling it out.
  3. kits de reparo de baterias de iPhone
    Only $29.99
    Buy Now
    Only $29.99
    Buy Now
  4. Press down on the top cover of the device and slid it towards you until you see a slight gap created. Lift the top cover off. Lift the top cover off.
    • Press down on the top cover of the device and slid it towards you until you see a slight gap created.
    • Lift the top cover off.
  5. Slide the body case back away from the bottom. Pull up the body case to remove it from the bottom. Pull up the body case to remove it from the bottom.
    • Slide the body case back away from the bottom.
    • Pull up the body case to remove it from the bottom.
  6. Remove the four 8mm screws at each corner of the motherboard with a JIS #0 screwdriver. Remove the four 8mm screws at each corner of the motherboard with a JIS #0 screwdriver.
    • Remove the four 8mm screws at each corner of the motherboard with a JIS #0 screwdriver.
  7. Lift the motherboard out of the casing. Lift the motherboard out of the casing.
    • Lift the motherboard out of the casing.
Conclusão
Zackery
Membro desde: 15-02-2018
347 reputação
2 Guias de autoria
Equipe
USF Tampa, Team S17-G6, Boczar Spring 2018 Membro de USF Tampa, Team S17-G6, Boczar Spring 2018
USFT-BOCZAR-S18S17G6
4 Membros
6 Guias de autoria
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 2
Todo: 90
