Ir para o conteúdo principal
Brightsign 4k Battery Replacement
O que você precisa
  1. Brightsign 4k Battery Replacement, Outer Shell: passo 1, imagem 1 %32 Brightsign 4k Battery Replacement, Outer Shell: passo 1, imagem 2 %32 Brightsign 4k Battery Replacement, Outer Shell: passo 1, imagem 3 %32
    • Remove three 8mm screws from the left side of the device.
    • Remove four 8mm screws from the right side of the device.
  2. Brightsign 4k Battery Replacement: passo 2, imagem 1 %32 Brightsign 4k Battery Replacement: passo 2, imagem 2 %32 Brightsign 4k Battery Replacement: passo 2, imagem 3 %32
    • Apply pressure on the SD card to pop it out of the port.
    • Remove the card by pulling it out.
  3. Brightsign 4k Battery Replacement: passo 3, imagem 1 %32 Brightsign 4k Battery Replacement: passo 3, imagem 2 %32 Brightsign 4k Battery Replacement: passo 3, imagem 3 %32
    • Press down on the top cover of the device and slid it towards you until you see a slight gap created.
    • Lift the top cover off.
  4. Brightsign 4k Battery Replacement: passo 4, imagem 1 %32 Brightsign 4k Battery Replacement: passo 4, imagem 2 %32 Brightsign 4k Battery Replacement: passo 4, imagem 3 %32
    • Slide the body case back away from the bottom.
    • Pull up the body case to remove it from the bottom.
  5. Brightsign 4k Battery Replacement, Motherboard Removal: passo 5, imagem 1 %32 Brightsign 4k Battery Replacement, Motherboard Removal: passo 5, imagem 2 %32
    • Remove the four 8mm screws at each corner of the motherboard with a JIS #0 screwdriver.
  6. Brightsign 4k Battery Replacement: passo 6, imagem 1 %32 Brightsign 4k Battery Replacement: passo 6, imagem 2 %32
    • Lift the motherboard out of the casing.
  7. Brightsign 4k Battery Replacement, Battery: passo 7, imagem 1 %32 Brightsign 4k Battery Replacement, Battery: passo 7, imagem 2 %32
    • Flip the motherboard over.
    • Desolder the two solder joints and remove the melted solder.
    • Beware of over heating the soldering kit will damage the logic board.
  8. Brightsign 4k Battery Replacement: passo 8, imagem 1 %32 Brightsign 4k Battery Replacement: passo 8, imagem 2 %32 Brightsign 4k Battery Replacement: passo 8, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Desoldering Pump
    $3.99
    Comprar
    • Apply the desoldering pump to remove the melted part from the motherboard (press the button to release it).
    • Pull the battery from the motherboard.
Conclusão
Tuong Ngo
Membro desde: 02/15/18
85 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team S17-G6, Boczar Spring 2018 Membro de USF Tampa, Team S17-G6, Boczar Spring 2018
USFT-BOCZAR-S18S17G6
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 4
Duração total: 404
