Introdução
The spark plug is responsible for igniting the fuel in your engine. Over time, it will wear out and need to be replaced. This replacement is fairly simple and can be done anywhere in little time. You will need a 2" long 13/16" socket wrench to remove the spark plug.
O que você precisa
Use your hands to remove the spark plug wire. It should pop off easily with little effort
Use a socket wrench with a 13/16" hex bit to unscrew the spark plug from the engine. You will probably need to use a long hex bit in order to get to the bolt.
Pull the spark plug out of its housing with your hands.
6 outras pessoas executaram este guia.
12 comentários
pinch the front of black cap and pull off
What size spark plug does this 675 series lawn mower take, I didn't see it listed?
