Ir para o conteúdo principal
Briggs and Stratton 675 Series Spark Plug Replacement
O que você precisa
  1. Briggs and Stratton 675 Series Spark Plug Replacement, Cap Removal: passo 1, imagem 1 %32 Briggs and Stratton 675 Series Spark Plug Replacement, Cap Removal: passo 1, imagem 2 %32
    • Make sure the engine is turned off before beginning.
    • Use your hands to remove the spark plug wire. It should pop off easily with little effort
  2. Briggs and Stratton 675 Series Spark Plug Replacement, Spark Plug Removal: passo 2, imagem 1 %32 Briggs and Stratton 675 Series Spark Plug Replacement, Spark Plug Removal: passo 2, imagem 2 %32 Briggs and Stratton 675 Series Spark Plug Replacement, Spark Plug Removal: passo 2, imagem 3 %32
    • Use a socket wrench with a 13/16" hex bit to unscrew the spark plug from the engine. You will probably need to use a long hex bit in order to get to the bolt.
    • Pull the spark plug out of its housing with your hands.
    • Alternatively, you may use a wrench or pliers to remove the spark plug instead. (Shown in the second image.)
Conclusão
6 outras pessoas executaram este guia.
Andrew Saunders
Membro desde: 02/01/15
957 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 6-31, Amido Winter 2015 Membro de Cal Poly, Team 6-31, Amido Winter 2015
CPSU-AMIDO-W15S6G31
Membros da 4
Autoria de 15 guias
12 comentários
I have a Briggs and Stratton engine on my lawn mower but can't get at the spark plug as there is some kind of black plastic housing in front of it.
penora - Responder
Any ideas I have a Briggs and Stratton engine on my lawn mower but can't get at the spark plug as there is some kind of black plastic housing in front of it.
penora - Responder
pinch the front of black cap and pull off
tracy.mullen - Responder
What size spark plug does this 675 series lawn mower take, I didn't see it listed?
Eris - Responder
Kymberleah - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 11
Últimos 7 dias: 140
Últimos 30 dias: 529
Duração total: 47,013
