Ir para o conteúdo principal
Briggs and Stratton 675 Series Repair Muffler Replacement
O que você precisa
  1. Briggs and Stratton 675 Series Repair Muffler Replacement, Muffler: passo 1, imagem 1 %32
    • Make sure the engine is off and the spark plug wire is removed and away from the spark plug before beginning.
    • Use a socket wrench with a 1/4" hex bit or a 1/4" wrench to remove the three 13mm screws holding the outer flange.
    • Remove the flange.
  2. Briggs and Stratton 675 Series Repair Muffler Replacement: passo 2, imagem 1 %32
    • Use a pair of needle nose pliers to bend back the two metal tabs on either side of the remaining screws.
    • Be careful not to break off the tabs.
  3. Briggs and Stratton 675 Series Repair Muffler Replacement: passo 3, imagem 1 %32
    • Use a socket wrench with a 7/16" hex bit or 7/16" wrench to remove the two remaining 75mm screws.
    • Make sure not to lose the metal bar linking the two screws.
  4. Briggs and Stratton 675 Series Repair Muffler Replacement: passo 4, imagem 1 %32 Briggs and Stratton 675 Series Repair Muffler Replacement: passo 4, imagem 2 %32
    • Remove the muffler from the engine block by simply pulling it away.
    • After removing the muffler, make sure to note the configuration of the washer assembly that sits between the muffler and the engine block (shown in photo 2). This piece will be free to fall out once the muffler is removed. Do not lose this piece.
Conclusão
Uma outra pessoa concluiu este guia.
Brad Wash
Membro desde: 02/02/15
476 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 6-31, Amido Winter 2015 Membro de Cal Poly, Team 6-31, Amido Winter 2015
CPSU-AMIDO-W15S6G31
Membros da 4
Autoria de 14 guias
Um comentário
When I removed the muffler from the engine block by simply pulling it away, the thermic regulator fell out and I don't see how/where to fix it again.
Thanks for any help !!!
yvessr - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 48
Últimos 30 dias: 177
Duração total: 13,175
