Ir para o conteúdo principal
Briggs and Stratton 675 Series Repair Air Filter Replacement
O que você precisa
  1. Briggs and Stratton 675 Series Repair Air Filter Replacement, Air Filter: passo 1, imagem 1 %32
    • Make sure the the engine is off and the spark plug wire is removed and away from the spark plug before beginning.
    • Use a Flathead #4 screw driver to remove the 40mm screw that holds the air filter case in place.
  2. Briggs and Stratton 675 Series Repair Air Filter Replacement: passo 2, imagem 1 %32
    • Use your hands to pull the air filter case out of the hinge at the bottom.
  3. Briggs and Stratton 675 Series Repair Air Filter Replacement: passo 3, imagem 1 %32
    • Simply remove the air filter with your hands.
Conclusão
6 outras pessoas executaram este guia.
Equipe
Cal Poly, Team 6-31, Amido Winter 2015 Membro de Cal Poly, Team 6-31, Amido Winter 2015
CPSU-AMIDO-W15S6G31
Membros da 4
Autoria de 15 guias
2 comentários
Good information, although it didn't resolve my issue. Thanks for sharing
all2thegoodpromo - Responder
This is a power wash motor water will not come out
hdoggett Doggett - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 11
Últimos 7 dias: 62
Últimos 30 dias: 279
Duração total: 19,530
