Ir para o conteúdo principal
Breville JE98XL Juice Fountain Plus Lid Replacement
  1. Breville JE98XL Juice Fountain Plus Lid Replacement, Pulp Basket: passo 1, imagem 1 %32
    • Place the juicer on a flat surface. Make sure the juicer is unplugged and in the "off" position. For the following steps, the pulp basket is on the left.
  2. Breville JE98XL Juice Fountain Plus Lid Replacement: passo 2, imagem 1 %32
    • Tilt the juicer slightly to the right so the pulp basket is off of your surface.
  3. Breville JE98XL Juice Fountain Plus Lid Replacement: passo 3, imagem 1 %32
    • Pull the pulp basket down and out from under the juicer cover.
  4. Breville JE98XL Juice Fountain Plus Lid Replacement, Lid: passo 4, imagem 1 %32 Breville JE98XL Juice Fountain Plus Lid Replacement, Lid: passo 4, imagem 2 %32
    • Place one hand on either side of the safety locking arm.
    • Disengage the locking mechanism by pulling down on the lever with even pressure. The lever should be free to move up or down once it has been properly disengaged.
  5. Breville JE98XL Juice Fountain Plus Lid Replacement: passo 5, imagem 1 %32 Breville JE98XL Juice Fountain Plus Lid Replacement: passo 5, imagem 2 %32
    • Firmly grip both sides of the juicer. Twist clock-wise and lift to remove the lid.
Conclusão
Kurt Wacker
Membro desde: 10/06/16
207 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team S23-G4, Livingston Spring 2017 Membro de Cal Poly, Team S23-G4, Livingston Spring 2017
CPSU-LIVINGSTON-S17S23G4
Membros da 4
Autoria de 19 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 15
Duração total: 303
