Ir para o conteúdo principal
Breville Duo-Temp 800ESXL Gasket Replacement
O que você precisa
  1. Breville Duo-Temp 800ESXL Gasket Replacement, Gasket: passo 1, imagem 1 %32 Breville Duo-Temp 800ESXL Gasket Replacement, Gasket: passo 1, imagem 2 %32 Breville Duo-Temp 800ESXL Gasket Replacement, Gasket: passo 1, imagem 3 %32
    • With your left hand, strongly grip the handle of the portafilter.
    • Pull the handle to your left. This will unlock the portafilter.
    • If the portafilter lock is too tight, place your hand on the top or bottom of the machine to provide additional leverage.
    • Gently push down to release the portafilter.
  2. Breville Duo-Temp 800ESXL Gasket Replacement: passo 2, imagem 1 %32 Breville Duo-Temp 800ESXL Gasket Replacement: passo 2, imagem 2 %32 Breville Duo-Temp 800ESXL Gasket Replacement: passo 2, imagem 3 %32
    • Slide the drip tray towards you to remove and set aside.
    • Two holes in the middle of the tray are available to make the tray easier to hold on to when removing.
    • Grasp the water reservoir using the front indention and the bottom of the tank.
    • Pull the water reservoir towards you to remove and set aside.
    • The drip tray and the water reservoir may contain water. Avoid spills if possible.
  3. Breville Duo-Temp 800ESXL Gasket Replacement: passo 3, imagem 1 %32
    • Carefully lay the espresso machine on its side.
    • The espresso machine is top heavy with the drip tray and the water reservoir removed.
  4. Breville Duo-Temp 800ESXL Gasket Replacement: passo 4, imagem 1 %32 Breville Duo-Temp 800ESXL Gasket Replacement: passo 4, imagem 2 %32 Breville Duo-Temp 800ESXL Gasket Replacement: passo 4, imagem 3 %32
    • Line the Phillips screwdriver up with the screw located in the center of the group head screen.
    • Turn the screwdriver counter clockwise to remove the 6 mm Phillips #1 screw.
    • If the screw is tight, use both hands to turn the screw driver.
    • Applying pressure to the screwdriver will help prevent stripping the screw.
  5. Breville Duo-Temp 800ESXL Gasket Replacement: passo 5, imagem 1 %32 Breville Duo-Temp 800ESXL Gasket Replacement: passo 5, imagem 2 %32
    • Insert the opening tool between the housing and the gasket.
    • Pry the gasket loose from the housing.
    • The screen is contained within the gasket and will not be damaged by prying the gasket loose.
  6. Breville Duo-Temp 800ESXL Gasket Replacement: passo 6, imagem 1 %32 Breville Duo-Temp 800ESXL Gasket Replacement: passo 6, imagem 2 %32 Breville Duo-Temp 800ESXL Gasket Replacement: passo 6, imagem 3 %32
    • Remove the gasket and screen from the machine.
    • Peel back the gasket from the screen in a circular motion.
    • If the gasket is firmly stuck to the screen, soak in warm soapy water for approximately 30 minutes to loosen the coffee buildup.
    • Discard the old gasket.
  7. Breville Duo-Temp 800ESXL Gasket Replacement: passo 7, imagem 1 %32 Breville Duo-Temp 800ESXL Gasket Replacement: passo 7, imagem 2 %32 Breville Duo-Temp 800ESXL Gasket Replacement: passo 7, imagem 3 %32
    • Soak the group head screen in warm soapy water.
    • Clean the group head with a nylon espresso machine brush and warm soapy water.
    • Scrub the group head screen with a nylon espresso machine brush.
    • The group head screen should be completely free of coffee oils and build up.
  8. Breville Duo-Temp 800ESXL Gasket Replacement: passo 8, imagem 1 %32 Breville Duo-Temp 800ESXL Gasket Replacement: passo 8, imagem 2 %32 Breville Duo-Temp 800ESXL Gasket Replacement: passo 8, imagem 3 %32
    • Place the group head screen inside the new gasket.
    • Firmly press the screen into the seal in a circular motion.
    • The screen fits snuggly but easily within the gasket.
  9. Breville Duo-Temp 800ESXL Gasket Replacement: passo 9, imagem 1 %32 Breville Duo-Temp 800ESXL Gasket Replacement: passo 9, imagem 2 %32
    • Place the gasket and screen back into the espresso machine.
    • Insert the 6 mm Phillips #1 screw back into the middle of the screen and tighten in a clockwise direction.
    • The tightness of the screw should be firm but not difficult to loosen. Do not over tighten the screw.
  10. Breville Duo-Temp 800ESXL Gasket Replacement: passo 10, imagem 1 %32 Breville Duo-Temp 800ESXL Gasket Replacement: passo 10, imagem 2 %32
    • Set the espresso machine upright.
    • Reattach the water reservoir and drip tray.
Conclusão
Your espresso machine is now ready to use. Fill your portafilter with coffee, brew and enjoy your espresso.
Carissa Baker
Membro desde: 09/20/21
181 Reputação
Autoria de 1 guia
2 comentários
thanks so much. Do you have a photo of the brew group without the screen on it? mine is so filthy and water was only coming out of one side-Lily
Lily White - Responder
Hi! Water is coming out of those holes on top when I try to make espresso. Does that mean I need to replace the gasket? What do you think the issue is? Thanks!
Haley Shanahan - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 16
Últimos 30 dias: 104
Ao todo: 6,404
