Ir para o conteúdo principal
Breville BKC600XL Water Valve Replacement
O que você precisa
  1. Breville BKC600XL Water Valve Replacement, "Bottom" Black Shell Piece: passo 1, imagem 1 %32 Breville BKC600XL Water Valve Replacement, "Bottom" Black Shell Piece: passo 1, imagem 2 %32 Breville BKC600XL Water Valve Replacement, "Bottom" Black Shell Piece: passo 1, imagem 3 %32
    • Remove the two 12mm black Phillips screws using a Phillips #0 screwdriver.
    • Reminder for reassembly; This bottom piece is first to be screwed back on.
  2. Breville BKC600XL Water Valve Replacement, "Top" Black Shell Piece: passo 2, imagem 1 %32
    • Remove the two 12mm Phillips screws using a Phillips #0 screwdriver.
  3. Breville BKC600XL Water Valve Replacement, Silver Casing: passo 3, imagem 1 %32 Breville BKC600XL Water Valve Replacement, Silver Casing: passo 3, imagem 2 %32 Breville BKC600XL Water Valve Replacement, Silver Casing: passo 3, imagem 3 %32
    • Remove the grey plastic casing.
    • Remove the two 12mm hexagonal screws using a 1.5mm hex screwdriver.
  4. Breville BKC600XL Water Valve Replacement, Water Valve: passo 4, imagem 1 %32
    • Cut the band connecting the hose to the water valve.
    • Remove the water valve.
    • Reminder for reassembly; You will need a new band to tie the hose back to the water valve.
Conclusão
Antonio
Membro desde: 09/26/12
120 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 1-3, Propen Fall 2012 Membro de Cal Poly, Team 1-3, Propen Fall 2012
CPSU-PROPEN-F12S1G3
Membros da 4
Autoria de 6 guias
2 comentários
Where can I buy a new water valve assembly? Are they custom to the device or generally available ? Thanks!
Betsy Goodrich - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 10
Duração total: 5,814
