Introdução
Replacing the spring should it fail to work.
O que você precisa
Remove the two 12mm black Phillips screws using a Phillips #0 screwdriver.
Remove the two 12mm Phillips screws using a Phillips #0 screwdriver.
Remove the grey plastic casing.
Remove the two 12mm hexagonal screws using a 1.5mm hex screwdriver.
Identify the spring and the hook its attached to.
Carefully remove the spring.
Quase terminado!
Conclusão
