Ir para o conteúdo principal
Breville BKC600XL On/Off Switch Replacement
O que você precisa
  1. Breville BKC600XL On/Off Switch Replacement, Bottom Cover #1: passo 1, imagem 1 %32 Breville BKC600XL On/Off Switch Replacement, Bottom Cover #1: passo 1, imagem 2 %32 Breville BKC600XL On/Off Switch Replacement, Bottom Cover #1: passo 1, imagem 3 %32
    • Use a Phillips #0 screwdriver to remove the following ten screws:
    • Four 18mm Phillips screws.
    • Four 9.75mm Phillips screws.
    • Two 8mm Phillips screws.
    • The cover will not remove entirely. Keep green ground wire attached to the cover.
  2. Breville BKC600XL On/Off Switch Replacement, Black Water Inlet: passo 2, imagem 1 %32 Breville BKC600XL On/Off Switch Replacement, Black Water Inlet: passo 2, imagem 2 %32
    • Remove the two 14.5 Phillips screws.
    • Ensure that only the water inlet valve can be moved.
  3. Breville BKC600XL On/Off Switch Replacement, Bottom Cover #2: passo 3, imagem 1 %32 Breville BKC600XL On/Off Switch Replacement, Bottom Cover #2: passo 3, imagem 2 %32
    • Use a Phillips #0 screwdriver to remove the following six screws:
    • Six 14.5mm Phillips screws.
  4. Breville BKC600XL On/Off Switch Replacement, Power Cord: passo 4, imagem 1 %32 Breville BKC600XL On/Off Switch Replacement, Power Cord: passo 4, imagem 2 %32
    • Remove the power cord from the groove. (the black cord that leads into the green wire.)
    • This creates more slack in the wire to give you more room to work with.
    • DO NOT remove green wire from the cover its attached to.
  5. Breville BKC600XL On/Off Switch Replacement, On/Off Switch: passo 5, imagem 1 %32
    • Carefully pull both the red and blue wires that covered at the tip.
    • Do not yank them out from the other end. Move them aside and out of the way.
  6. Breville BKC600XL On/Off Switch Replacement: passo 6, imagem 1 %32
    • Carefully remove the On/Off Switch from its slot on the outside cover.
    • The wires for the switch need to be tied back into the wires that lead to the battery. If needed, use electrical tape.
Conclusão
Antonio
Membro desde: 09/26/12
120 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 1-3, Propen Fall 2012 Membro de Cal Poly, Team 1-3, Propen Fall 2012
CPSU-PROPEN-F12S1G3
Membros da 4
Autoria de 6 guias
2 comentários
Any source for the switch?
Mark Bell - Responder
Thanks to this great post, I replaced my Breville BKC700XL On/Off Switch. The momentary switch is JR Products 12815 Black SPST Mini Mom-On/Off Switch, $8 on Amazon. https://www.amazon.com/dp/B002UC6QY0?psc...
Now, my Breville single serve is like new. I almost ordered a new machine, then I found ifixit. Kudos to you guys.
Boyd Gilbert - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 18
Duração total: 3,537
