Ir para o conteúdo principal
Breville BKC600XL Heating Tank Replacement
O que você precisa
  1. Breville BKC600XL Heating Tank Replacement, Bottom Cover #1: passo 1, imagem 1 %32 Breville BKC600XL Heating Tank Replacement, Bottom Cover #1: passo 1, imagem 2 %32 Breville BKC600XL Heating Tank Replacement, Bottom Cover #1: passo 1, imagem 3 %32
    • Use a Phillips #0 screwdriver to remove the following ten screws:
    • Four 18mm Phillips screws.
    • Four 9.75mm Phillips screws.
    • Two 8mm Phillips screws.
    • The cover will not remove entirely. Keep green ground wire attached to the cover.
  2. Breville BKC600XL Heating Tank Replacement, Black Water Inlet: passo 2, imagem 1 %32 Breville BKC600XL Heating Tank Replacement, Black Water Inlet: passo 2, imagem 2 %32
    • Remove the two 14.5 Phillips screws.
    • Ensure that only the water inlet valve can be moved.
  3. Breville BKC600XL Heating Tank Replacement, Bottom Cover #2: passo 3, imagem 1 %32 Breville BKC600XL Heating Tank Replacement, Bottom Cover #2: passo 3, imagem 2 %32
    • Use a Phillips #0 screwdriver to remove the following six screws:
    • Six 14.5mm Phillips screws.
  4. Breville BKC600XL Heating Tank Replacement, Power Cord: passo 4, imagem 1 %32 Breville BKC600XL Heating Tank Replacement, Power Cord: passo 4, imagem 2 %32
    • Remove the power cord from the groove. (the black cord that leads into the green wire.)
    • This creates more slack in the wire to give you more room to work with.
    • DO NOT remove green wire from the cover its attached to.
  5. Breville BKC600XL Heating Tank Replacement, Clear Hose: passo 5, imagem 1 %32 Breville BKC600XL Heating Tank Replacement, Clear Hose: passo 5, imagem 2 %32
    • Identify the hose that connects to the heating tank. (Observe that it is held up on a small hook.)
    • Push down on the hook and carefully move the hose from its grip.
  6. Breville BKC600XL Heating Tank Replacement, Heating Tank: passo 6, imagem 1 %32
    • Carefully pull out the heating tank by hand.
    • The heating tank may still be hot. Exercise caution when grabbing hold of the tank. If necessary, wait four to six hours after last use.
    • Reminder for reassembly; You will need a new band to tie the hose back to the heating tank.
Conclusão
Antonio
Membro desde: 09/26/12
120 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 1-3, Propen Fall 2012 Membro de Cal Poly, Team 1-3, Propen Fall 2012
CPSU-PROPEN-F12S1G3
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 9
Duração total: 4,580
