Ir para o conteúdo principal
Brentwood TS-292B Toasting Lever Replacement
O que você precisa
  1. Brentwood TS-292B Toasting Lever Replacement, Toasting Lever: passo 1, imagem 1 %32 Brentwood TS-292B Toasting Lever Replacement, Toasting Lever: passo 1, imagem 2 %32
    • Use a Phillips #2 screwdriver to remove all of the 6mm screws from the bottom of the toaster.
  2. Brentwood TS-292B Toasting Lever Replacement: passo 2, imagem 1 %32 Brentwood TS-292B Toasting Lever Replacement: passo 2, imagem 2 %32 Brentwood TS-292B Toasting Lever Replacement: passo 2, imagem 3 %32
    • Push in the small tab located to the left, and pull the lever tab away from the toaster with force.
    • Remove the toaster cover carefully.
  3. Brentwood TS-292B Toasting Lever Replacement: passo 3, imagem 1 %32
    • Detach the bundled cable connector by carefully pulling it away from the circuit board.
  4. Brentwood TS-292B Toasting Lever Replacement: passo 4, imagem 1 %32 Brentwood TS-292B Toasting Lever Replacement: passo 4, imagem 2 %32
    • Push the tabs in and lift the top of the toaster off.
  5. Brentwood TS-292B Toasting Lever Replacement: passo 5, imagem 1 %32 Brentwood TS-292B Toasting Lever Replacement: passo 5, imagem 2 %32 Brentwood TS-292B Toasting Lever Replacement: passo 5, imagem 3 %32
    • Lift up the tab that is located at the front of the toasting lever.
    • Use tweezers to carefully lift up the metal bar.
    • Remove the springs and replace them with new ones.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 7
Duração total: 563
