Ir para o conteúdo principal
Brentwood TS-292B Browning Dial Circuitboard Replacement
O que você precisa
  1. Brentwood TS-292B Browning Dial Circuitboard Replacement, Browning Dial Circuitboard: passo 1, imagem 1 %32 Brentwood TS-292B Browning Dial Circuitboard Replacement, Browning Dial Circuitboard: passo 1, imagem 2 %32 Brentwood TS-292B Browning Dial Circuitboard Replacement, Browning Dial Circuitboard: passo 1, imagem 3 %32
    • Remove the five screws indicated using a Philips head screwdriver.
  2. Brentwood TS-292B Browning Dial Circuitboard Replacement: passo 2, imagem 1 %32 Brentwood TS-292B Browning Dial Circuitboard Replacement: passo 2, imagem 2 %32
    • Pull hard on the browning lever until it detaches from the toaster.
    • It will take some force to pull it off.
    • Once the tab is off, lift up on the housing to remove it from the toaster.
  3. Brentwood TS-292B Browning Dial Circuitboard Replacement: passo 3, imagem 1 %32
    • Once the housing has been pulled upwards, carefully uplug the wire connecting the browning dial circuit board to the main circuit board.
  4. Brentwood TS-292B Browning Dial Circuitboard Replacement: passo 4, imagem 1 %32 Brentwood TS-292B Browning Dial Circuitboard Replacement: passo 4, imagem 2 %32
    • There are four screws on the circuit board for the browning dial.
    • Unscrew each of them with a Philips head screwdriver to detach the board and remove the board and dial from the toaster housing.
  5. Brentwood TS-292B Browning Dial Circuitboard Replacement: passo 5, imagem 1 %32 Brentwood TS-292B Browning Dial Circuitboard Replacement: passo 5, imagem 2 %32
    • There are two holes on the board where the pin from the browning dial can align.
    • Refer to the images if you are having trouble finding them.
    • Replace the browning dial by inserting the pin on the dial into one of the holes indicated.
    • Replace the entire circuit board if need be.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 11
Duração total: 246
