Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Turn the toaster upside down.
Remove the five 6 mm screws with a Phillips #2 screwdriver.
Grasp the plastic pull lever cover firmly and pull to remove it. This may require force.
Lift the cover upwards to remove it.
To detach the bundled cable connector, carefully pull it away from the circuit board.
Pull the toaster lever down.
While holding the toaster lever down, use the spudger to pull the metal tabs away from the wired bread grabber.
Continuing to hold the toaster lever down, pinch the wires inward and pull up to carefully remove them from the toaster.
