Ir para o conteúdo principal
Introdução
This guide provides instructions on how to remove and replace the bread grabber in the Brentwood TS-292B.
Peças
Nenhum componente especificado.
  1. Turn the toaster upside down. Remove the five 6 mm screws with a Phillips #2 screwdriver.
    • Turn the toaster upside down.
    • Remove the five 6 mm screws with a Phillips #2 screwdriver.
  2. Grasp the plastic pull lever cover firmly and pull to remove it. This may require force. Lift the cover upwards to remove it.
    • Grasp the plastic pull lever cover firmly and pull to remove it. This may require force.
    • Lift the cover upwards to remove it.
    • When removing the cover, do not damage the cable connector bundle that attaches the cover to the toaster.
  3. To detach the bundled cable connector, carefully pull it away from the circuit board.
    • To detach the bundled cable connector, carefully pull it away from the circuit board.
  4. Pull the toaster lever down. While holding the toaster lever down, use the spudger to pull the metal tabs away from the wired bread grabber.
    • Pull the toaster lever down.
    • While holding the toaster lever down, use the spudger to pull the metal tabs away from the wired bread grabber.
    • Continuing to hold the toaster lever down, pinch the wires inward and pull up to carefully remove them from the toaster.
Conclusão
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 222
