Introdução
This is a step-by-step guide demonstrates how to remove the battery.
WARNING: This is a lithium battery which should be handled with care.
TIPS:
- Be sure to check the screwdriver heads before performing this task; otherwise, screws may become damaged.
- Use an ice cube tray or egg carton, place each screw in its own cup to organize the screws.
O que você precisa
Flip the Braven BRV-X upside down so you are facing the bottom side.
With the H1.5 Head Screwdriver, unscrew the four screws.
Using the #0 Phillips screwdriver, unscrew the four screws on the four corners of the bottom side.
Gently remove the outer casing, which should reveal the inner shell.
Remove the black foam squares from the red, yellow, and black wire on the top right side of the device.
5 outras pessoas executaram este guia.
10 comentários
Thank you for the replacement steps - do you know where I could buy a replacement battery?
Anyone ever figure out what battery they needed?
I also would love to know what battery is actually needed for this.
Parallel or series connection?
