Introdução
If your speaker sound is muffled or broken, the speaker cone may be damaged. To solve this problem, you can remove the old speaker cone and replace it with a new part. This guide will show you how to access the speaker cone and remove it. The guide will include the necessary prerequisites needed.
O que você precisa
To remove the outer case, remove 4 phillips screws (Phillips #00 headtype, 9.3mm long)
To remove the speaker cone plate, remove 10 phillips screws (Phillips #00 headtype, 9.3mm long)
Using a metal spudger, gently pry the side of the defective speaker cone plate.
Remember to pry all around the side of the speaker cone plate.
Keep in mind that the adhesive will make it difficult to pry the plate off. To loosen the adhesive, heat the plate with a device such as a hair dryer.
