Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Loja
Peças
Nenhum componente especificado.
  1. To remove the outer rubber casing use a 3mm Hex bit to remove the 4 large 12mm Hex screws on both sides, found on the bottom part of the device.
    • To remove the outer rubber casing use a 3mm Hex bit to remove the 4 large 12mm Hex screws on both sides, found on the bottom part of the device.
  2. Using the Metal Spudger, carefully pry each side of the rubber casing away from the device.
    • Using the Metal Spudger, carefully pry each side of the rubber casing away from the device.
    • A little resistance should be felt, but not enough to bend the spudger.
  3. SKIP THE UPGRADE
    Save by fixing with an all-in-one kit.
    Shop iPhone Fix Kits
    SKIP THE UPGRADE
  4. To remove the hard inner plastic casing, use a Phillips #00 head bit to remove the 16 small 9mm screws surrounding the subwoofer on the top side of the device.
    • To remove the hard inner plastic casing, use a Phillips #00 head bit to remove the 16 small 9mm screws surrounding the subwoofer on the top side of the device.
  5. Carefully lift away the broken sub-woofer plate of the device. Replace with functioning sub-woofer plate.
    • Carefully lift away the broken sub-woofer plate of the device. Replace with functioning sub-woofer plate.
Conclusão
Erik Oliva
Membro desde: 14/02/2018
607 Reputação
6 Guias de autoria
Equipe
USF Tampa, Team S2-G1, Eyestone Spring 2018 Membro de USF Tampa, Team S2-G1, Eyestone Spring 2018
USFT-EYESTONE-S18S2G1
4 Membros
6 Guias de autoria
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 60
