Ir para o conteúdo principal
Braven BRV-1M Outer Casing Replacement
O que você precisa
  1. Braven BRV-1M Outer Casing Replacement, Outer Casing: passo 1, imagem 1 %32
    • To remove the outer casing, use a 3mm Hex bit to remove the 4 large 12mm Hex screws on both sides of the device.
  2. Braven BRV-1M Outer Casing Replacement: passo 2, imagem 1 %32
    • Using the Metal Spudger, carefully pry each side of the rubber casing away from the device.
    • A little resistance should be felt, but not enough to bend the spudger.
  3. Braven BRV-1M Outer Casing Replacement: passo 3, imagem 1 %32
    • To remove the inner plastic casing, use a Phillips #00 head bit to remove the 16 small 9mm screws surrounding the top side of the device.
  4. Braven BRV-1M Outer Casing Replacement: passo 4, imagem 1 %32
    • Carefully lift away the housing and replace the broken casing/component. Replace using the new casing.
Conclusão
Uma outra pessoa concluiu este guia.
Erik Oliva
Membro desde: 02/14/18
607 Reputação
Autoria de 6 guias
Equipe
USF Tampa, Team S2-G1, Eyestone Spring 2018 Membro de USF Tampa, Team S2-G1, Eyestone Spring 2018
USFT-EYESTONE-S18S2G1
Membros da 4
Autoria de 6 guias
Um comentário
Where can I buy parts for this speaker? My rear charging door has broken off disabling the ruggedness. Be easier to buy versus build new piece.
Michael Harruff - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 13
Duração total: 600
