Ir para o conteúdo principal
Braven BRV-1M Battery Replacement
O que você precisa
  1. Braven BRV-1M Battery Replacement, Outer Casing: passo 1, imagem 1 %32
    • To remove the outer casing, use a 3mm Hex bit to remove the 4 large 12mm Hex screws on both sides of the device.
  2. Braven BRV-1M Battery Replacement: passo 2, imagem 1 %32
    • Using the Metal Spudger, carefully pry each side of the rubber casing away from the device.
    • A little resistance should be felt, but not enough to bend the spudger.
  3. Braven BRV-1M Battery Replacement: passo 3, imagem 1 %32
    • To remove the inner plastic casing, use a Phillips #00 head bit to remove the 16 small 9mm screws surrounding the top side of the device.
  4. Braven BRV-1M Battery Replacement: passo 4, imagem 1 %32
    • Carefully lift away the housing and replace the broken casing/component. Replace using the new casing.
  5. Braven BRV-1M Battery Replacement, Motherboard: passo 5, imagem 1 %32
    • To remove the motherboard, proceed to unscrew the 3 Phillips #00 bit type, 13mm long screws located on both sides of the motherboard.
  6. Braven BRV-1M Battery Replacement: passo 6, imagem 1 %32
    • Then, proceed to unscrew the 5 Phillips #00 bit type, 9mm long screws located on the face of the charging dock.
  7. Braven BRV-1M Battery Replacement: passo 7, imagem 1 %32
    • Disconnect the two 4-pin auxiliary button register cables connected on both sides of the motherboard.
  8. Braven BRV-1M Battery Replacement: passo 8, imagem 1 %32
    • Once disconnected, carefully remove the motherboard by pulling upwards.
  9. Braven BRV-1M Battery Replacement, Battery: passo 9, imagem 1 %32
    • To remove the battery, unscrew the 2 Phillips #00 bit type, 9 mm long screws on both sides of the battery.
  10. Braven BRV-1M Battery Replacement: passo 10, imagem 1 %32
    • Gently pull the battery from the housing of the device while disconnecting the red, white and black wires coming from the battery.
Conclusão
Erik Oliva
Membro desde: 02/14/18
607 Reputação
Autoria de 6 guias
Equipe
USF Tampa, Team S2-G1, Eyestone Spring 2018 Membro de USF Tampa, Team S2-G1, Eyestone Spring 2018
USFT-EYESTONE-S18S2G1
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 10
Últimos 30 dias: 20
Duração total: 2,244
