Ir para o conteúdo principal
Braun Series 7 790cc-7 Charging Base Wire Harness Replacement
O que você precisa
  1. Braun Series 7 790cc-7 Charging Base Wire Harness Replacement, Charging base wire harness: passo 1, imagem 1 %32
    • Remove the cleaner cartridge from the charging base.
  2. Braun Series 7 790cc-7 Charging Base Wire Harness Replacement: passo 2, imagem 1 %32 Braun Series 7 790cc-7 Charging Base Wire Harness Replacement: passo 2, imagem 2 %32 Braun Series 7 790cc-7 Charging Base Wire Harness Replacement: passo 2, imagem 3 %32
    • Depress the 4 tabs while lightly pulling the cover from the base.
    • Next, depress the 2 molded tabs while still pulling the cover from the base.
  3. Braun Series 7 790cc-7 Charging Base Wire Harness Replacement: passo 3, imagem 1 %32
    • Press inward on the side charging port while pulling cover from the base to separate.
  4. Braun Series 7 790cc-7 Charging Base Wire Harness Replacement: passo 4, imagem 1 %32 Braun Series 7 790cc-7 Charging Base Wire Harness Replacement: passo 4, imagem 2 %32
    • Remove side charging port by prying tabs outward and rotating port upward.
  5. Braun Series 7 790cc-7 Charging Base Wire Harness Replacement: passo 5, imagem 1 %32 Braun Series 7 790cc-7 Charging Base Wire Harness Replacement: passo 5, imagem 2 %32
    • Remove charging terminals by inserting a spudger from bottom the and sliding terminals up.
  6. Braun Series 7 790cc-7 Charging Base Wire Harness Replacement: passo 6, imagem 1 %32 Braun Series 7 790cc-7 Charging Base Wire Harness Replacement: passo 6, imagem 2 %32
    • Remove solder from circuit board and remove charging harness.
Conclusão
Uma outra pessoa concluiu este guia.
Ian Hayes
Membro desde: 11/07/17
219 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team S3-G6, Harley Fall 2017 Membro de IUPUI, Team S3-G6, Harley Fall 2017
IUPUI-HARLEY-F17S3G6
Membros da 3
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 18
Duração total: 1,109
