Introdução
The charging base wire harness is essential to the function of the Braun Series 7 790cc-7 charging base. Many consumers may discard the charging base if it cannot be used to charge and clean the razor. This can be expensive but by replacing a faulty charging harness the razor can be used with the charging base again. With the use of this Replacement Guide, one can easily change the charging base harness if required.
O que você precisa
Uma outra pessoa concluiu este guia.
