Ir para o conteúdo principal
Braun Series 7 790cc-7 Battery Replacement
O que você precisa
  1. Braun Series 7 790cc-7 Battery Replacement, Battery: passo 1, imagem 1 %32 Braun Series 7 790cc-7 Battery Replacement, Battery: passo 1, imagem 2 %32
    • Use a spudger to remove the rubber piece on the back of the razor.
  2. Braun Series 7 790cc-7 Battery Replacement: passo 2, imagem 1 %32
    • Use a Torx T8 to remove (4) 10 mm screws from housing.
  3. Braun Series 7 790cc-7 Battery Replacement: passo 3, imagem 1 %32 Braun Series 7 790cc-7 Battery Replacement: passo 3, imagem 2 %32
    • Remove the rear cover from the device.
  4. Braun Series 7 790cc-7 Battery Replacement: passo 4, imagem 1 %32
    • Remove the battery from the holster inside the device.
  5. Braun Series 7 790cc-7 Battery Replacement: passo 5, imagem 1 %32
    • Replace the battery with a new 1300 mAh Sanyo (UR18500Y) battery.
    • Be sure to insert the battery the correct way.
Conclusão
27 outras pessoas executaram este guia.
Alex Speer
Membro desde: 11/07/17
763 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team S3-G6, Harley Fall 2017 Membro de IUPUI, Team S3-G6, Harley Fall 2017
IUPUI-HARLEY-F17S3G6
Membros da 3
Autoria de 5 guias
27 comentários
Any idea on how to remove/replace the drive unit? I bought a new one but the plastic backing is extremely hard to get off.
Chris - Responder
Thank you for the awesome tutorial Alex!
I just wanted to comment that a small flat-head screw driver can be used to remove the 4 screws (under the rubber handle piece) if you don’t have a Torx tool. The screws each have 1 small slot across the head and if you’re careful you can remove and re-install them without too much trouble.
Thanks again for helping to save me a lot of trouble with this Alex… and avoid having to buy a new electric razor!
-jb-
arcticassault - Responder
How do you reset the battery life indicator on the shaver after replacement?
jclemis - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 19
Últimos 7 dias: 140
Últimos 30 dias: 685
Duração total: 54,650
