Introdução
Diese Anleitung führt dich in das Innere der Kaffemühle. (Neidische Blicke deiner Hipster Freunde sind garantiert, da die Mühle der Inbegriff von "vintage" ist)
O que você precisa
Entferne zuerst den Mahlgutbehälter.
Um das Geräte wieder zusammenzusetzen führe die Anleitungsschritte in umgekehrter Reihenfolge aus.
16 outras pessoas executaram este guia.
Um agradecimento especial a esses tradutores:
100%
Estes tradutores estão nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
9 comentários
Hi Daniel,
Thanks for the tutorial.
Would you have, by any chance, the usermanual of the grinder?
I’m wondering to what grinding size the numbering is corresponding to.
Many thanks! :)
Best regards,
Greg
I have this same issue! Did you ever find out? Im guessing that the grind size of the KMM1 is the same as the KMM20? So left (where it says mocca)for finest grind, right for the largest grind?
Look at the explosion view
Umm.. My bottom burr doesn’t seem to have screws and look like rivits. maybe previous owner stripped the screws :(
Mine has something like rivets as well. I used toothpicks and cotton swabs to clean as much as I could,, then had some luck running dried couscous through the grinder. Softer than rice and seemed to pick up the last bits of residue.
