Ir para o conteúdo principal
Braun Aromaster KF440 one-way valve Replacement
O que você precisa
  1. Braun Aromaster KF440 one-way valve Replacement, Access the base: passo 1, imagem 1 %32
    • Remove the carafe (coffee pot) from the coffee maker.
    • Turn the Braun Aromaster KF 440 upside down so the base is exposed.
  2. Braun Aromaster KF440 one-way valve Replacement, Remove the nut: passo 2, imagem 1 %32
    • Locate the nut at the center of the base and unscrew it with a pair of basic pliers.
  3. Braun Aromaster KF440 one-way valve Replacement, Remove the cover: passo 3, imagem 1 %32
    • Gently lift the cover away from the bottom of the coffee maker and remove it.
  4. Braun Aromaster KF440 one-way valve Replacement, Locate internal one-way valve: passo 4, imagem 1 %32
    • Locate the one-way valve.
  5. Braun Aromaster KF440 one-way valve Replacement, Pull out valve: passo 5, imagem 1 %32
    • Lift up on the one way valve to snap it out of place. (This shouldn't require much force).
  6. Braun Aromaster KF440 one-way valve Replacement, Push tube off the one-way valve: passo 6, imagem 1 %32
    • Using the larger plastic opening tool, gently push the tubing off of the one-way valve. (If the tubing is being stubborn and won't come off, run the metal spudger around the inside of tubing to free it up.)
  7. Braun Aromaster KF440 one-way valve Replacement, Lift valve: passo 7, imagem 1 %32
    • Completely remove one-way valve from the inside of the coffee maker.
Conclusão
3 outras pessoas executaram este guia.
Dennis
Membro desde: 10/20/14
315 Reputação
Autoria de 2 guias
Equipe
Baylor, Team 8-12, Williams Fall 2014 Membro de Baylor, Team 8-12, Williams Fall 2014
BU-WILLIAMS-F14S8G12
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 14
Últimos 30 dias: 29
Duração total: 3,277
