Introdução
Removing the base is necessary in order to reach many of the other major components of the coffee maker.
O que você precisa
Remove the carafe (coffee pot) from the coffee maker.
Turn the Braun Aromaster KF 440 upside down so the base is exposed.
Locate the nut at the center of the base and unscrew it with a pair of basic pliers.
Gently lift the cover away from the bottom of the coffee maker and remove it.
2 comentários
Can’t remove nut. Soooo small. Plus, clockwise… Or counter clockwise?
Das Problem istnicht die das Entfernen der Mutter wie beschrieben, sondern die Schraube die nur mit einem Spezial-Schraubenzieher geloesst werden kann. Und den gibts nicht zu kaufen. Oder?
