Ir para o conteúdo principal
Braun 5514 Battery Replacement
O que você precisa
  1. Braun 5514 Battery Replacement, Battery: passo 1, imagem 1 %32
    • Remove any attached trimmer heads by gripping and pulling away from the body.
  2. Braun 5514 Battery Replacement: passo 2, imagem 1 %32 Braun 5514 Battery Replacement: passo 2, imagem 2 %32 Braun 5514 Battery Replacement: passo 2, imagem 3 %32
    • Insert an opening pick between the top plate and the grey separator.
    • Slide the opening pick around the perimeter of the plate to release the hidden clips.
  3. Braun 5514 Battery Replacement: passo 3, imagem 1 %32
    • Remove the four 7.0mm Torx T6 screws attaching the grey plastic frame to the black plastic casing.
  4. Braun 5514 Battery Replacement: passo 4, imagem 1 %32 Braun 5514 Battery Replacement: passo 4, imagem 2 %32
    • Use the opening pick to lift the grey frame from the black casing.
  5. Braun 5514 Battery Replacement: passo 5, imagem 1 %32 Braun 5514 Battery Replacement: passo 5, imagem 2 %32
    • Remove the circuit board assembly from the frame.
  6. Braun 5514 Battery Replacement: passo 6, imagem 1 %32
    • Pull the small black plastic piece out of the frame.
  7. Braun 5514 Battery Replacement: passo 7, imagem 1 %32 Braun 5514 Battery Replacement: passo 7, imagem 2 %32
    • Desolder the four tabs connecting the batteries to the circuit board.
    • Repeat for the other side of the battery.
Conclusão
22 outras pessoas executaram este guia.
Andrew Kluckhuhn
Membro desde: 07/05/18
959 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team S2-G2, Harley Summer 2018 Membro de IUPUI, Team S2-G2, Harley Summer 2018
IUPUI-HARLEY-SU18S2G2
Membros da 4
Autoria de 5 guias
10 comentários
What is the name/part nr. of the battery?
Casper Smit - Responder
Thanks!
This manual is applicable for the model 5516, too :-)
The battery type should be: AAA 1000 mAh; make sure, to choose batteries, that are prepared for soldering!!
Lucas B - Responder
Same goes for 5515.
Thanks for the guide :)
Yordan Chanev - Responder
Thanks, I was looking how to take apart 5513, similar enough, as far as the battery replacement goes, any rechargeable AAA battery should do. Batteries don’t like the heat from soldering iron, there are kits for welding batteries, another idea is to get cheap battery holder if you can fit it in.
Mariusz Lewicki - Responder
Does the 1.2V Ni-MH AAA 1000mAh battery work, have an older model MGK5280 ?
Thanks.
Jhon Jones - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 19
Últimos 7 dias: 126
Últimos 30 dias: 656
Duração total: 41,122
