Introdução
Use this guide to learn how to replace your battery for the Bowers and Wilkins T7 Bluetooth Speaker.
O que você precisa
Ferramenta utilizada neste passo:Tweezers$4.99
Gently squeeze the internal locking mechanism inside the red and white terminals with either your fingers or a pair of precision tweezers.
While squeezing the internal locking mechanism, pull back the terminal.
Repeat this process for the second speaker.
Using a cutting tool such as a Jimmy steel blade or wire cutter, cut the cable tie surrounding the battery.
9 outras pessoas executaram este guia.
3 comentários
Bravo ! Le choix de cet appareil symbolique !
No repair any repairing sentar
