Ir para o conteúdo principal
Bottom Cover
O que você precisa
  1. Bottom Cover, Battery: passo 1, imagem 1 %32
    • Before proceeding, power down your Laptop and remove the power cable.
    • Close the display and lay it on a flat surface, top-side down.
  2. Bottom Cover: passo 2, imagem 1 %32
    • Unlock the battery by sliding the battery lock to the unlock part.
  3. Bottom Cover: passo 3, imagem 1 %32
    • Slide the middle lock to the right and the battery will pop up.
  4. Bottom Cover: passo 4, imagem 1 %32
    • If you want to replace the battery and nothing else then now is the time to do so.
    • Once the battery hatch is unlocked you can now safely remove the battery.
  5. Bottom Cover, Bottom Cover: passo 5, imagem 1 %32
    • Use a Philips J1 driver to remove eight screws securing the bottom case.
    • Remove all of the 8 screws and the bottom panel should pop off.
  6. Bottom Cover: passo 6, imagem 1 %32
    • After that you are in and now can change most of the components, which we also have tutorials for.
Conclusão
Regome
Membro desde: 01/20/23
794 Reputação
Autoria de 7 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 5
Ao todo: 152
