Ir para o conteúdo principal
Boston Electric Pencil Sharpener Cutter Replacement
O que você precisa
  1. Boston Electric Pencil Sharpener Cutter Replacement, Cutter: passo 1, imagem 1 %32 Boston Electric Pencil Sharpener Cutter Replacement, Cutter: passo 1, imagem 2 %32 Boston Electric Pencil Sharpener Cutter Replacement, Cutter: passo 1, imagem 3 %32
    • Remove the tray from the front of the pencil sharpener and empty the pencil shavings.
    • Make sure the pencil sharpener is unplugged!
  2. Boston Electric Pencil Sharpener Cutter Replacement: passo 2, imagem 1 %32 Boston Electric Pencil Sharpener Cutter Replacement: passo 2, imagem 2 %32 Boston Electric Pencil Sharpener Cutter Replacement: passo 2, imagem 3 %32
    • Unscrew the three screws securing the bottom of the sharpener.
    • The screwdriver must be 6” long to reach the two screws in the front of the sharpener.
  3. Boston Electric Pencil Sharpener Cutter Replacement: passo 3, imagem 1 %32 Boston Electric Pencil Sharpener Cutter Replacement: passo 3, imagem 2 %32
    • Lift the motor and cutter from the top case of the sharpener.
    • Carefully move the wires so that the case can be completely removed.
    • You shouldn’t have to disconnect any wires to take the case off. If so, contact the manufacturer.
  4. Boston Electric Pencil Sharpener Cutter Replacement: passo 4, imagem 1 %32 Boston Electric Pencil Sharpener Cutter Replacement: passo 4, imagem 2 %32
    • Unscrew the protective case around the cutter by locating the two screw on the front of the sharpener.
  5. Boston Electric Pencil Sharpener Cutter Replacement: passo 5, imagem 1 %32 Boston Electric Pencil Sharpener Cutter Replacement: passo 5, imagem 2 %32 Boston Electric Pencil Sharpener Cutter Replacement: passo 5, imagem 3 %32
    • Use the socket wrench to remove the two bolts in the back of the sharpener.
    • You need to remove the motor in order to reach the back of the cutter.
  6. Boston Electric Pencil Sharpener Cutter Replacement: passo 6, imagem 1 %32
    • Carefully separate the motor and the case around the motor from the cutter.
    • Guide the wires through the holes in the casing to detach them from the cutter section of the sharpener.
  7. Boston Electric Pencil Sharpener Cutter Replacement: passo 7, imagem 1 %32 Boston Electric Pencil Sharpener Cutter Replacement: passo 7, imagem 2 %32
    • Unscrew the sharpener with a small standard screwdriver and remove the long screw to loosen the cutter.
    • Make sure to hold the cutter to keep it from rotating.
  8. Boston Electric Pencil Sharpener Cutter Replacement: passo 8, imagem 1 %32
    • Replace the cutter.
    • WD-40 would be helpful, but not necessary.
Conclusão
Uma outra pessoa concluiu este guia.
Randy Yonce
Membro desde: 09/29/15
101 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 10-1, Green Fall 2015 Membro de Cal Poly, Team 10-1, Green Fall 2015
CPSU-GREEN-F15S10G1
Membros da 4
Autoria de 6 guias
6 comentários
Great instructions on replacing the sharpener. My father took the model 18 apart but failed to document with pictures on the step by step breakdown. I'm left with out a crucial part of the re- installment. The question is in step 7, the piece right behind and below the screw driver is a plastic piece with two wires comming out of it. where does this piece fit? any help or redirection to a site that might have this info. direct reply at
thopper1@satx.rr.com
tah33 - Responder
tah33 - that part is the switch that senses the pencil to turn on power. There is a plastic piece that goes over the top of the cutting mechanism to help guide all the shavings down into the shavings tray. The switch goes onto the front of that piece. If you look at step 4 it shows the switch mounted to the piece I am talking about,  Randy (the author) calls it the protective case.
David Ryan - Responder
Steps 5 and 6 are not required.
jffleck - Responder
The wire nuts were loose and came off, is there a way to know for certain which wires go together?
Alan Budd - Responder
The link to purchase a new cutting blade brings you to Amazon, and it's not available. Any other place that FOR sure the part is available?
North Flower - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 11
Últimos 30 dias: 57
Duração total: 8,367
