Ir para o conteúdo principal
Boss RC-1 Loop Station-Pedal Battery Replacement
O que você precisa
  1. Boss RC-1 Loop Station-Pedal Battery Replacement, Battery: passo 1, imagem 1 %32
    • Push down on the pedal in order to relieve pressure on the thumbscrew.
  2. Boss RC-1 Loop Station-Pedal Battery Replacement: passo 2, imagem 1 %32
    • Remove the thumb screw at the bottom of the device.
    • Loosening the thumb screw far enough will also allow the pedal to open.
  3. Boss RC-1 Loop Station-Pedal Battery Replacement: passo 3, imagem 1 %32 Boss RC-1 Loop Station-Pedal Battery Replacement: passo 3, imagem 2 %32
    • Using the Phillips #0 screwdriver, remove the two screws that secure the pedal to the device.
  4. Boss RC-1 Loop Station-Pedal Battery Replacement: passo 4, imagem 1 %32
    • Take the battery out of the device.
  5. Boss RC-1 Loop Station-Pedal Battery Replacement: passo 5, imagem 1 %32
    • Disconnect the snap chord from the battery.
  6. Boss RC-1 Loop Station-Pedal Battery Replacement: passo 6, imagem 1 %32
    • Reassemble the device in the opposite order.
    • When tightening the thumbscrew back in the device, apply force to the pedal first (Do step 1 before step 2).
Conclusão
To check if the batter replacement was successful, plug in a guitar cable into the “Output A” jack. If the red light turns on below the “check” (top of the device), then the looper pedal is working.
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 13
Últimos 30 dias: 64
Duração total: 6,390
