O que você precisa
Of all of the places where the wire can tear down, this is the most common, and also the most inconvenient to fix.
Remove the sticker to be able to access the screw that holds the two halves of the casing together
The screw is tiny and requires some kind of tiny wrench that I don't have, so I made the whole a bit bigger around it to be able to unfasten it with regular pliers.
with a thin tool like those on mobile phone repair kits, open the casing
Cut the wire and check that everything works but plugging a multimeter to the wires. This way you make sure there's nothing else wrong.
get two pieces of heat shrink shield on each of the wires before doing any soldering
Solder the wires to the ends on the casing. Make sure to respect polarity! The negative end is marked with a dashed line
Place the heat shrink shield over the soldering and apply heat to seal
the bit that protects the wire as it comes out of the casing needs to be cut in half to be reused, and you also want to make the hole in the middle larger so that the new soldered wires fit
A bit of hot glue will keep things in place
Add some electrical tape for extra firmness and insulation
Put back the screw, the sticker and with a multimeter check that you've got the desired voltage output, in the correct polarity!
